boundary selection problem
When I move the pointer to a certain boundary and click, an adjacent boundary lights up
instead of the boundary I pointed at, how do I resolve this?
thanks
David
PS
this is a problem that suddenly turned up on all files including gallery models
2 Replies Last Post Dec 21, 2012, 5:22 a.m. EST
Posted: 1 decade ago Dec 21, 2012, 3:32 a.m. EST
click several times until you get to the desired boundary,
or it's an issue with your graphics card, try using software rendering, and update COMSOL and/or graphics drivers if required. But check the version and compatibility list before changing everything ;)
Hi click several times until you get to the desired boundary, or it's an issue with your graphics card, try using software rendering, and update COMSOL and/or graphics drivers if required. But check the version and compatibility list before changing everything ;) -- Good luck Ivar
Posted: 1 decade ago Dec 21, 2012, 5:22 a.m. EST
Thanks Ivar,
Ok the problem is also with domains : when I click on domain 2 - domain 1 lights up, when I click on domain 3
domain 2 lights up etc. There are only 6 domains so when I click on 1 then domain 6 lights up.
It doesn't look like a graphics problem.
David
Hi Thanks Ivar, Ok the problem is also with domains : when I click on domain 2 - domain 1 lights up, when I click on domain 3 domain 2 lights up etc. There are only 6 domains so when I click on 1 then domain 6 lights up. It doesn't look like a graphics problem. David
